Deere 813 plow trip standards
Don Loch
Has anyone ever worked on these. Mine were rusted up and wouldn"t move. Noticed the tubular shims sandwiched between the plates and located on two of the 1/2 bolts going thru plates. I think a combination of these shims control pressure to trip. Is there a rebuild procedure when setting these standards up? I put everything back the way it was found but looks like someone may have had this apart before.
(quoted from post at 00:55:17 03/31/09)
I had my 810 plow all apart a year ago. Yes the combination of the tubular shims control the pressure of the trip. Each shim added will increase the tripping load by 600 pounds. The larger shims must be assembled over the smaller shims.
Don
Here is a parts break down of your plow maybe this will help.
http://jdpc.deere.com/jdpc/pdfs/PC0390.PDF
Budd
Make sure the roller turs freely on the trip latch. I use never-seez on them and on the pivot for the beam. There is an ecentric cam to take the slap out of the latch, make sure it works. Get the bolt on the beam pivot as tight as possible without binding to elimenate side play.
I've taken one off the plow and carefully removed one of the plates. Made sure all parts remained firmly in other plate. Don't really understand how this assembly works. There are two of the smallest tubular shims, one on each of the half inch bolts. In addition the bottom bolt has a larger shim over the small one. The shim on the top bolt don't look like it does anthing. There is a flat washer under the shim on the top bolt. The bottom ones seem to position the latch. Is the cam being spoke of locked with jam nuts? It still was locked with jam nut on other plate. Looked like something adjustable. Didn't move it.
The upper tube shim is just a spacer between the plates. The lower one goes under the tail of the leaf spring that controls trip presure. The cam has a jam nut on each side and is rotated with a screwdriver. The latch asembly will come out without separating the two plates. The coil spring is only a return spring and has nothing to do with trip presure. The latch moves forward forward and up to trip.
Here is a cut away of it.
