Deere bale thrower not throwing correct
tomstractorsandtoys
I have a model 30 bale thrower on my 24t baler. Have owned for over 25 years. Today when baling the distance became erratic. Sometimes with it on 6 the bales would go to the back of the wagon and sometimes barely over the front. By the time I quit it was doing the same thing on 8 sometimes hitting the back and sometimes just over the front. We are baling straw that has no wet spots or heavy bunches. The 2 drive belts are tight and there is plenty of oil in the thrower tank. It is new hyd oil as we had a leak in a line last summer. When the oil was out the filter appeared very clean. Where do I start? The operaters manual gives no ideas. I remember my old Deere dealer talked about taking the distance control valve apart and adding a small amount of grease every few years. When we baled lots of small bales we would take it to the dealer every two or so years and have it completly gone over. Now that we moved and only bale 2500 or so a year we haven't done that for awhile. Any ides? We have 1500 or more bales of straw to make and the weather is good right now. Thanks Tom.
There is a cap on the control valve held on with I think two bolts/screws. Inside are some small parts, clean them, add grease, and put back on. Sounds like those parts are sticking and the valve is not returning to the home position.
Agree - my control valve was sticking and with some cleaning and grease, the ejector works great now. I think the service manual may suggest greasing/cleaning every year.
When mine sticks, the kicker will not trip at all, but that is probably best place to start. Also, make sure the thrower ram spring is not broken inside.
Operators manual and service mamual would be to different things. Operators just to tell you how to use, not how to maintain, Then the parts still different. Should have all 3 on hand before you tear into something like that. Service manual just how to do something and parts to tell you how many of each item so you do not loose some in taking apart. And I have never seen one of those units so know nothing about it except for any repair job have all manuals and read them before starting
