I'm in the process of an in-frame rebuild on a JD 1630 with 3-179 engine, my first diesel rebuild. I decided to use JD bearings for mains and rods. When I picked them up, the thrust bearing was the "newer" flangless style.
Ok, so I ask the guy at the counter, do I need thrust washers, and he says I don't think so, nothing came up as needed extra on the computer, and he's not seen anybody get washers with bearings before.
Ok, I guess, magical bearings. As fate should have it I didn't get the rear bearing installed that day, so I called my machine shop. He said he didn't work on JD personally but he thought it would need separate thrust washers.
Does anybody know if JD makes/sells magical thrust bearings that don't require separate thrust washers? They do have thrust washers for other bearings, but I can't prove it for mine. Do I need a new parts guy? Thanks.
