Delayed vs Selective Lift
Wilks54
I recently purchased back my Grandpa's mounted cultivator (C-254) for his old C, and also picked up a manual since I have no idea how to use them or put it all together. I received some help earlier from you guys with identifying which cultivator model they were, so thanks for all your guy's help to date!
I was reading the manual, and there is a delayed lift and selective lift option for the rear. Looks like the set ups are different. I know the selective lift in the front allows you to set different heights for the front left and front right side, but does that also work for the back? Also, does the rear set up actually have a delay after you put them down with the touch control.
Thanks for any help/advice you guys can offer!
the rear cylinder was a delay lift and drop. when you got to the end of the row, the front gangs would lift first then the rear, letting you cultivate right up to the headrow. same with the drop. the delay was controlled by a valve mounted right on the rear cylinder.
