Delco 10-SI Data Sheet
This data sheet tells it all about how to hook up the 10-SI used in the 12V conversion kits!
The kits should have this document in there!
With the dash light and remote sense hooked up correctly, then you can get your darn charging current at low RPM with good regulation.
Check the Delco Remy website for this service bulletin.
http://www.delcoremy.com/pdfs/service_manuals/legacy/1G-269.pdf
Greg
Delco Remy 10 SI Service Bulletin in PDF
No problem,
Also the bulb can be the #68 bayonet type double contact automotive bulb (since neither side sees ground).
Cole-Herse has the insulated socket that comes with a bulb.
I have the part # for the socket if needed.
The dash hole is around 3/4" to 7/8".
Greg
Hi Greg, many thanks for the Delco service bulletin
it will be very helpful for me/us in the future.
Thanks again !
Joe Ferguson
(quoted from post at 16:51:25 02/11/10) Interesting that they refer to it as a "Generator" rather than an alternator.
Well, that's probably because it makes (generates) electrical current. (Some foks call them AC-generators.)
We probably should call a generator ..an "alternator"... because depending upon rotational speed it.. alternates between producing current and not as it's cut-in/cut-out cycles. :lol:
(quoted from post at 12:05:17 02/12/10)
ow about "an alternator with a mechanical rectifier, aka commutator/brushes".
