Got a delco rigged up to charge up the battery, everything is working great. I have everything wired up direct.(the heavy red wire going directly to pos batt) out of curiosity I checked with the volt meter between pos battery post and pos battery cable. with the tractor not running i have voltage running through. if i disconnect the heavy red wire off the alt charge stud the voltage drain goes away.
is the heavy red supposed to be disconnected through a key switch(when done properly) to prevent this?
like I said i have it rigged up "temporary" for charging, am I missing something?
thanks
david
thanks
david
