Delco-Remy Generator Models
Ohio Hills
I"m going to need to replace the 12v generator on my Oliver Super 55. The original Delco-Remy generator is a model 1100322. A friend has a 12v model 1100321 that he will sell me. Does anyone know the difference between a 1100322 and a 1100321?
<a href="http://www.delcoremy.com/Documents/Quick-Reference-guide-2009.aspx">here it is</a> (PDF file)
I don't see those part numbers though. Are you sure they weren't 1100231 and 1100232? If so, those two look identical.
(quoted from post at 11:13:25 03/31/11) I"m going to need to replace the 12v generator on my Oliver Super 55. The original Delco-Remy generator is a model 1100322. A friend has a 12v model 1100321 that he will sell me. Does anyone know the difference between a 1100322 and a 1100321?
They use different commutator end frames different armatures, different drive end frames, and different drive end bearings.
The specifications are a little different.
1100321 has a maximum field draw of 1.5 to 1.62 amps at 12 volts. Maximum amperage output 25 amps. 14 volts. Rated RPM 2710.
1100322 has a maximum field draw of 1.58 to 1.67 amps at 12 volts. Maximum amperage output 20 amps. 14 volts. Rated RPM 2300.
If one had a bushing in the CE frame and the other a ball bearing that could account for the frame and armature numbers. If the mounting holes are correct the generators should interchange.
