Deutz 6206 Loader Hookup
Lathamgx30
Hello everyone,
First time posting here! I just picked up a Deutz 6206 that has a loader attached. It is currently hooked in through the auxiliary valve for my remotes below and to the right of the seat, which is not correct and leaves me with not remote hydraulics. I have to have that valve activated in order to operate the loader, which is a pain. I am wondering where I should hook into the system so that its not going through a valve to the loader valve, but I can't find any information on that even though I downloaded the operators manual. Any advice would be appreciated, and or photographs if anyone had a Deutz with a loader on it.
Gary
Welcome Lathamgx30!
I really can't answer directly relating to that tractor, but most aux remotes
running off the belly pump are either/or, not both at the same time.
If that is the way it was plumbed when you got it, that's probably how it's set
up to work.
If you need to do serious loader work you may have to add a front pump just for
the loader.
Just a guess, maybe someone will come on with a better answer.
Thanks Steve@Advance,
I have thought about adding a second pump to the system, and probably will at some point.
I would like to think that the way it is plumbed is the way it should be, however; the people I got it from weren't, shall we say, the farming type, and in reading the operators manual it has a special "important" note that says "Never use terminal unit for operating the front-end loader."
But the manual also does not go into any detail on where and how to plumb the front end loader into the system.
I was hoping for a photograph of someone else's set up with a Deutz tractor, so I can see if my thought process is correct or not.
