deutz 6207 air filter
ghunziker
Can anyone give me the parts number for the large air filter for a deutz D6207. Where might I find one? Thanks for any help.
Go to www.wix.com and you can look up the WIX filter number.
The same filter is available at NAPA, just delete the first digit of the WIX number.
Is there a brand and any numbers on the end of your filter? You might be able to cross reference that info on a site like WIX filters, if they are legible. You can take a look at the site I linked below, and see if it gives you enough info to ID your filter, for certain, to one of these, using the dimensions. You should then be able to cross one of the manufacturer's numbers they show to one you can get locally.
https://www.malpasonline.co.uk/itm/Air-Filters/Air-Filter-Outer-AF4137-for-deutz-fahr-d-6207/108905
