Deutz tractor. Need help please
56oliver
I have a 6206 deutz that the PTO shaft bearing went out of today. Its that one on the very end under the plate with 4 bolts holding it on. The shaft bow has a lot of play in it obviously.... My question is. Where can I get a new bearing and how do I put it in? Do I need to pull the transmission apart or can I do it by taking the plate off? Thanks for any help guys
Agco or a deutz fahr dealer, allis chalmers dealer. Pretty sure you
pop that plate that the pto shaft sticks out of in the back of the
tractor. There is probably a seal to replace also and maybe an o-ring
or gasket. Engage the pto before you takethe plate off the back.
(Engine not running when working on it or course)
