dewalt cordless sawzall
bfullmer
it an older model that has some sort or load sensing speed control is ther any way to bypass and run full speed ? Now it goes from low to high while cutting and back to low speed
Sounds like the tool is worn out.
I have never saw a DeWalt cordless Sawzall change speeds with the trigger fully depressed unless the battery was going dead.
Now I don't lie, and I don't murder.
But I just might steal your catalytic converter.
If you leave it unattended in a parking lot
I got a sawzall blade that's mighty hot.
Cut it right off and you'll be stuck.
Cause your Toyota be sounding like a plug wood truck..
Some tools adjust the power to the tool to keep a consistent speed under different loads.
Some tools have a progression trigger that allows the user to adjust the speed.
While I have not used every tool out there every reciprocating saw (sawzall is a trade name) I have ever used is of the progression trigger type.
I had quite a number of older DeWalt cordless tools with triggers that went bad and I replaced. Mostly drills.
