Dexta 3-point lift problem
When I move the 3-point lift adjustment lever from bottom to top, on my 1960 Dexta, it will sometimes rise to full height, then drop to about half-height. Other times it will only rise to half-height. Oil is full. Position/Draft lever is in the up position (lever handle facing front of tractor). I haven't yet removed the lift from the tractor, so I don't know about the condition of the cam follower pin. Is this pin the likely cause of the problem or are there other things I should check? Thanks.
Marlin
Yes sounds like the pin is worn.
Brian
Once exposed, does the pin just slide/screw out or need to be pulled/driven out? Are they available after-market or dealer only? Thanks.
Marlin
