Diesel fuel
Did they change something with the fuel. The last stuff that I put in the tractor makes it start really hard and it does not have near the power. I know this sounds like the tractor needs to be rebuilt, but it happened just as soon as I filled the tank with the latest fuel.
Could be you got a bad batch of fuel. It might have had water in it, or sediment. Or you could maybe have gotten some low sulfur stuff instead of the "old" type of diesel?
See if there is anything in your water separator or if you have a plugged filter, and start troubleshooting from there.
All diesel fuel on the market is Ultra Low Sulfur. I would check your filters and tank for water, sediment or black slime. If you find black slime you have algae in your fuel and you are going to need to add a biocide to kill it.
like said, its all ultra low sulfur and does not have the lubricity of the old stuff, we have to add diesel additives to our tank or we have the same problems, its made by standyne. Hope this helps, toby.
Is the fuel a biodiesel blend? The bio fuel is a good detergent and dissolves dirt in your system. May have to replace the filters a few times till the gunk is removed... Gene
Most likely you got a tank of Furnace oil instead of diesel fuel...
Hard starting is the marker... as Furnace oil has no cetane improvers.
I think the power would be fine if you get the tractor good and hot.
Rod
