Back to the 3600 drip drip drip while running. First of all I can't exactly locate the source. I thought it was the seals (steel orings) on the distributor output adapter to the fuel line up to the injector, on the bottom of the pump......one on the outboard is in plain sight and isn't the problem. Replaced them, compressed as Diesel Tech specified....... originals had no signs of damage......leak continued. The leak is definitely lower on the body of the pump, not the top gasket or anything atop half way up the unit, but on the back side.
On the back side of the pump is (as you know) very unaccessible both visually and mechanically.
I had this wild idea that it might be the seals on the injector line, back side of the pump that are almost impossible to see much less fix.
What if I follow that pipe up to the respective injector and disconnect the pipe at the injector which should relieve the pressure on the pipe, run the tractor (limping) and if drip stops dripping, or the dripping has slowed, then I think one could expect it to be one or both of those two steel orings on that cylinder and that finding would encourage me to walk the walk and replace those seals.
Am I nuts or does this wild idea have merit?
It would take a long time to leak a gallon of diesel and that is a moot cost. The problem is that it makes a mess and I am getting tired of putting up with that.
Thanks,
Mark
Thanks,
Mark
