I have been spending a lot of time trying to locate a dripping leak associated with my pump. Currently it appears that the leak is at the lower pump output, one of 3 areas that feed the injector pipes. The line to the injector doesn't appear to be leaking, nor around its retaining nut at the pump. What appears to be leaking is a flat adapter (from a fuel pipe) squared off , flat top and bottom, around the locking mechanism (3 surfaces the 4th being the fuel line) adjacent to that output that apparently is contained by a closed top nut. I assume that the nut's purpose is to secure that line.
I have an expensive service manual on the 3600 and it talks about this and that but doesn't get down to the nitty-gritthy of the fuel system and its components.
What is the purpose of that closed top nut....to hold that flat adapter against the pump, essentially sealing the interface? Is there a seal(s) involved, with respect to the flat flange under the nut that could have failed allowing fuel to drip out?
I have posted this before and from time to time I keep working on it.......having fuel slobbering from that problem area is really undesirable.
Comments certainly appreciated.
