Differences between 2355 and 2355N
Mathias NY
Does anyone have a good handle on the differences between these 2 tractors? From pictures it looks as though the N"s have a swept back front axle (possibly identical to the 2155) and smaller rear wheels.
Are they are any other differences I should be aware of and can I install a normal 146/175 loader onto an N?
Thanks for the help.
I"ve been doing some more looking. It appears that the 2355N"s have a turbocharged 179 3-cylinder engine (same size as a 2155) and the 2355"s are a 235 4-cylinder engine. This explains why the N"s appear shorter. So I"m concluding that the N"s are basically just a turbocharged 2155, with smaller rear tires.
2355N Rear axle housings(L56214) aren't the same as 2355
(AL38154)
differential(RG & pinion) are the same
collar shift trans cases are the same
SYNCHRONIZED TRANSMISSION cases are the same
