Steve (NC)
Hello All,
I got a flat in one of my rear tires and had to take wheel off. Decided I was going to replace brakes while it was off. Bought some parts including axel nuts (ordered 4179). When I went to take the axel nut noticed it was a larger inner diameter than the one I ordered on one side the the tractor. The other side matched what I ordered. The odd side appeared to have a threaded sleeve over the axel and then a wider inner diameter nut. Unfortnately means I will have to buy another socket. Any ideas what is going on?
Also discovered axel was leaking oil on brake pads. Can I clean them up or should I replace them? They look like there is still a lot of pad left.
Thanks,
Steve
Thanks,
Steve
