Henrik Jansson
I am checking the backlash of the bevel ring gear, not because something was wrong, but because I was going to install new gaskets between gearbox housing and rear axle housing, and power take out housing.
And then everything is removed, I can see the differential, so I checked it out. The tractor has been used for almost 5000 hours.
I can see some small damages on the pinion gear, but not that much that I think it is a problem. There is no damages on the bevel gear.
But the backlash between bevel gear and pinion gears is up to 0,40 mm, and the manual says it should be between 0,18-0,23mm.
I guess this backlash increase over the time, so maybe this is normal after 5000 hours, but should I adjust this?
According to the manual it looks easy to adjust only this backlash, but, if I do that, do I have to adjust the pinion shaft protrusion first? In the manual they do so, but I guess they do so just because they renew the whole thing. But can I just adjust the backlash of the bevel gear?
