Differential lock
37 chief
My JD 401B industrial doesn't have a differential lock. You would think it being a industrial tractor it would have the option. The only hope I have
is using the brake on the spinning wheel. Someone told me that told me that on here. It seams to work I have used it several times. Doing a mowing
job yesterday my left tire slopped over the edge of a wet area. I was moving fore ward, but couldn't climb out. I tapped the left brake, and the
right wheel pulled me out. Stan
I have differential lock on 4010 mule only problem is you have to enguage it before you need it. Can't enguage while moving.
I had a 1962 XKE Jaguar, limited slip differential. On snow covered road, you turned front wheels and kept going straight. I had to burp the gas peddle, spin the rear wheels, slide the rear end sideways to turn.
Both terramites have limited slip. Both rear wheels want to keep you going straight muddy conditions when you are working under load. Front wheels just slip and slide, you go straight.
If I want to turn I have to backing up to point front end directions I want to go.
Differential lock out will work if you are stuck. I just tap the brakes like you did.
Guess that's why tractors have 2 brake pedals.
George
Very common to use a little brake on spinning wheel to even things out. Especially when plowing with one rear wheel in the furrow and the other on land that might have wet grass on it. Fun to go downhill on snow covered ground and lock one brake. Gives a nice boost in speed.
Same here, ever since I was big enough to push the pedals. I guess driving in slippery muddy conditions or using a loader tractor will teach you. Mark.
You can also apply some brakes on any vehicle with open diff and one brake pedal to help put power to both tires.
Applying the brake part way will make the diff "think" both sides have traction and thus send power to both sides.
Hey, locking one wheel on ice can really get some good donuts going also as well as increased forward speed. Wasn't there some posts the other day about doing things we thought were safe.
An open differential always transmits equal torque to both axle shafts, regardless of what is providing the resistance. If the traction available at one wheel can only provide X ft-lb of resistance before spinning then the other wheel will likewise only be provided with X lb-ft of torque, even if it's available traction could take more than that. (Note that in extreme cases, such as when one wheel is in the air, X can equal zero meaning no driving force is being transmitted to anywhere.) By riding the brake on the low traction wheel you are adding the torque required to overcome the brake to both sides of the differential (since, again, the torque is always equal on both sides of an open differential) so this additional torque becomes available to drive the opposite wheel on the good traction surface.
Your not the only one, I have a Case tractor that was intended for construction work and it doesn't have a differential lock. On the other hand I have a little Kubota that is small enough you could fit it in the back of your truck that does have the differential lock.
