Difficulty getting Ford 3000 to fire
NJClark7
I have a 1971 Ford 3000 Select-o-speed diesel with a Simms fuel pump. I serviced it with new filters, gaskets and fluids this summer and got it running well. This is my first diesel tractor. Recently, I was so enamored with tilling up my ground I didn't realize I had ran out of diesel fuel. Thinking this was like an unleaded vehicle, I filled it up with 4.5 gallons of diesel and tried to start it. To my surprise the battery will crank but the engine won't fire. There is grey diesel smoke coming out of the exhaust and the battery is healthy, cranking at 10.8 V. Now, I know I'm an idiot and should have never let the tractor run out of diesel. Air had gotten into the fuel lines. I have bled the fuel filters, attempted to bleed the Simms pump (Although diesel only comes out when the engine is cranked, not by the small hand pump), and I have bled the 3 fuel injectors where they meet the engine. I am at a loss here, what else should I do to get it firing? Thank you all for your help and wisdom.
To bleed a Simms pump, you open the bleed screw on the side then pump the hand pump until all the bubbles are out of the fuel.
To start, I would then:
1 Make sure the fuel shut off is fully in.
2 Pull the throttle lever fully back
3 On the pivot of the throttle on the pump, there is a button (under a rubber cover). Push that in. You will hear a sound (TINK).
That sound is the fuel rack going to max.
4 Turn over the engine using the starter. You should see black smoke as you are at max fuel volume.
5 As soon as it starts firing move the throttle to half speed.
6 The engine will sputter some then clear up as the air is removed from the system.
Rereading your question, you state that the hand pump will not push fuel out of the bleeder.
After retrying that several times, I would question if that hand pump is defective?
You can also try a light spray of starter fluid at the air intake if all else fails. Don't overdue the amount, and spray only while cranking.
I would have suggested pull starting, but with an SOS you can't due that.
HTH
Keith
IF the hand pump is on a cam lobe, you will need to bump the engine a bit so that it can now pump. The hand pump can be cheaply replaced with an aftermarket pump if needed. BUT.. you bleed the filter first, then hand pump the primary side of the inj pump till it runs out of the little bleeder screw with no bubbles,,, then you can start to crank and bleed the high pressure side. DO NOT over tighten anything on the injector pump as it can and will strip out... Then you really have problems... Also you can bleed the tractor with starting fluid if you very lightly spray it into the air intake while cranking... and actually run the engine,, til it picks up the diesel fuel.
Thank you for the feedback. I will try this starting fluid method. My mechanic friend is coming tomorrow to look at it with me and get it going. I appreciate the insight and will update you guys if we get it running!
Gentlemen, thank you for your help in solving the matter. My mechanic friend came over and we got it solved within the hour. It was simply a matter of continuing to bleed the fuel injector lines while also cranking with a portable heavy duty battery charger attached to the battery so it didn't drain beyond practical usage. Long story short, don let your 1970s diesel tractor ever run out of fuel.
Don't let any of them run out of fuel
Thank you again for all your help. So an update on things. Right now, the tractor only starts after probably 10+ minutes of continuous cranking with a Schumacher 250 amp charger attached to the battery. The battery is a new Duralast battery with 1000 A CCA. I've also got and replaced the manual lift fuel pump. Without the Schumacher 250 amp charger attached, this is what's happening the tractor actually fires and sounds like it's starting after I've cranked for 30 seconds and it even seems like everything's firing and then the moment I let go of the key and quit cranking it dies. Now my push-in excess-fuel button is stuck on my Simms pump, could this be a symptom or cause of something?
You must have the throttle set at more than half way to make the excess fuel button go in... . . . .. When you run a fuel tank empty, you also suck all the fine powder and rust off the bottom of the tank that the low fuel splashing around, worked loose. SO... often you fuel outlet screen is stopped up and the filter/s are now clogged. The first filter should have the sediment bowl at the bottom pulled off and check for water, powder, and debris. turning on the fuel at this point should show a steady stream out the fuel filter housing. If not.. its at the tank or fuel line to the tank. Filter should be examined to see if it needs replacement. Often this means the inj-pump get little or no fuel. 10 minutes of cranking def means either no fuel, bad inj pump, or no compression. I'm betting no fuel if it ran and started well before.
Thanks for the reply. I checked sediment bowls on my two fuel filters and there's a little bit of black/brown sediment but not a large amount. Fuel filters themselves look very clean. I also had fuel flow freely from the bottom rigid fuel inlet from the fuel tank to my manual lift pump and it came out unobstructed. I did not check the fuel filter within the fuel tank itself though. I will say that the push-in excess fuel pump button on the Simms pump is very stuck and won't move regardless of the throttle position.
Have you changed the oil in the Simms Pump?
no I have not done anything regarding the Simms pump besides bleeding the air out of it.
Those pumps need the oil changed in order for the rack to move smoothly.
If the oil has been neglected that rack may not be moving. The rack may be stuck at the low end of it's output range.
Getting the rack to move may be your 1st objective.
HTH
Keith
First thing i would do is replace that battery with the correct 4LDT tractor battery that was original for the tractor. Even though the battery you have is new it does not have enough reserve power to start that diesel engine, As you can already see that engine has to spin fast to start. Those automotive batteries might start a diesel engine in warm weather if, the engine was in really good condition but, if your engine is in an older machine and maybe down on compression it will take the correct battery to start the tractor. And even then, it may also need a shot of starting fluid on the first start on a cold day. And Keith is correct you, need to service that pump and that needs to be done carefully and correctly with the same oil you use in the engine. The instructions can be found in the service manual. If you do not have manual you need to get one for your tractor. Change that battery, make sure the cables and cable ends and starter are in good shape and service that pump and things should work a lot better.
Forgive me, I may have miscommunicated my battery type. It's a Duralast Group Size 4DLT Heavy Duty Commercial Batter. The cables and cable ends are new too and a heavier gauge. I will look into serving the Simms Fuel Pump 4665 itself. At this point, it seems it's either that or the starter not cranking fast enough. Again, thank you for the feedback.
Ok sorry, I assumed from your description of the battery that it was not a 4LTD. You are good to go with the new cables and battery. Service your pump and if still having trouble do this, with the starter spinning the engine spray a small amount of starter fluid into the breather pipe. Too much will lock things down. This will help start the engine. Just be sure the engine is turning when you spray the fluid. You engine or pump may be worn enough to cause the cranking problem. It happens on older diesel engines.
Get oil in that pump.
Then work the throttle lever up and down. Pulling to full off should reset the button on the pivot point, Then full throttle, press button.
Hopefully you can get the rack to free up.
Read back thru old posts, I seem to remember a person being able to free that rack up.
Check that the cable is pushing/pulling the lever on the pump the whole way (fully off/fully on).
Your guys' input is very useful. I think at this point with winter approaching I may be bringing in the local mobile diesel tractor mechanic to look at it so I can get it running ASAP. I live in central Washington and we're getting dumped on with snow and rain in the coming week. At this point I may should be asking advice on if it's worth it to till up and dryland seed in heavy clay soil saturated with melted snow.
