Digital meter or not...?
banjoman09
Seems when I check my charging systems with a decent ($20) digital multi-meter that the voltage read out jumps around when
checking for charging..is there something better guys that will just show Volts on a steady screen? Thanks.
Better is a meter that can average 3 or 4 seconds of input to arrive at a real average instead of a single sample taken in about a millisecond. The meter you have is good for the normal, good quality accurate stable source. The old vehicles and tractors we work on are electrically noisy. meaning that at at any one millisecond the actual voltage may be 50, 121, 17, or 7. Assuming it charges. The ignition system, voltage regulator points, and generator brushes all spark and arc. each moment the instantaneous voltage can be anywhere. So There are three possible solutions #1 A cheap analog VOM with a needle and scale (18 bucks or so) they rely on the needle's inertia to stay put averaging the garbage in the wires. They are not critical level accuracy. The second is a Quality analog VOM from Simpson, Triplett I have a 3030, Gardner Bender. these can cost 175+ used. They are as accurate as any disgital, but ease of use requires more thinking. The third is a 100+ dollar digital with auto ranging and certified accuracy. Fluke Drives this boat, but Triplett, and Klein, are in the game. Jim
Probably more than you want to spend but I use either a Simpson 260 (old guy analog VOM) or a more modern Fluke 179 True RMS VOM
Are you using it on a tractor generator? That is when I usually have trouble. The way they work is the voltage goes up until the regulator contacts open, when it drops they close and go back up until the voltage makes them open again. So up/down/up again.
A good working analog meter (with a dial) will work.
Charging voltage is checked at the battery.
Also the meter's battery voltage maybe too low.
Minimum voltage on those cheap HF battery with a 9 volt battery is 8.4 volts.
They get goofy if the voltage drops that low,
Guido.
I don't think there is a cheap digital what won't dance around.
Get a cheapie analog meter.
I use this meter, not cheap.
Advanced Battery Conductance/Electrical System Tester Midtronics MDTPBT300
Brand New
$278.99
There may be cheaper conductivity testers.
It won't dance around. Clips on to battery, measures cranking voltage, charging voltage. Uses a conductivity test to estimate battery cranking amps. The amps it measures on new batteries is the amps stamped on battery. Even more because room temp is warmer..
I carry this one in truck, don't leave home without it.
For charging system diagnosis - especially on older stuff with generator/alternator and a mechanical mechanical regulator - nothing works better than an old time VOM like a Simpson 260, Triplett 630, etc.
Cheap DVMs like from HF are pretty much useless, except perhaps for checking voltage on a battery at rest. High quality DVMs (Fluke, etc) will work but are spendy.
FWIW I own a pair of Fluke DVM's - a 77 and an 87iii. But I drag out my ancient Simpson 260 for messing with old tractors.
Banjoman, Having owned and repaired such things as old generator equipped cars trucks and tractors for 50 some odd years plus todays more modern alternator systems, here is what I prefer.
My old trusty reliable Simpson 260 ANALOG VOM with its damping characteristics works great on old car truck n tractor charging troubleshooting as the meter doesn't jump around like the screen on some digital VOM's
For later model electricals/electronics I have BOTH a cheap Digital VOM as well as a Fluke Digital VOM (for its accuracy)
I think there's a time and place for all three of my meters, but for old tractors it the Simpson ANALOG hands down
John T Im sure others use and prefer different meters for their reasons, these are ONLY my opinions while others may well differ, to each their own
