ramtuff
How about you old? Could you post the Radio Shack#'s on the altenator diodes you did about a month or so ago?I wrote the #'s down an went an bought them.I've
lost them all. Thanks;
In the event you cant pick up the diodes, use (I prefer them actually) a 10 to 50 ohm resistor which provides some degree of current limiting safety (plus prevents run on same as diode) or else use a small incandescent idiot light bulb as a charge indicator...This refers to the excitation circuit for GM 10 SI alternators on the little No. 1 terminal... The diode works fine, Ive seen em with no diodes,,,,,,,,with diodes,,,,,,,,with idiot lights,,,,,,,,,with resistors (my preference)
John T
