dip stick holder
johnnymac
I would like to know if an 8N oil dip stick tube will fit in a Ford Jubilee tractor. When I go to check the oil the tube will come out 2" with the dip stick. I can find a tube for 2N,9N and 8N but none for a NAA Jubilee. Will one of these others fit and if not any suggestions will be appreciated. Thank you
From the parts site, the dipsctick tube for the 8N looks like it was completely different than the ones for the NAA. The parts site actually shows 2 different dip stick tubes for the NAA (Jubilee). Prior to S/N 18094 the part number is EAF6784B, and after S/N 18093 the part number is EAF6784A, and the later part number looks to have continued through the rest of the 4 cylinder 134 and 172 ci gasoline engines up to and including the 4 cylinder 2000 and 4000 series, so if your Jubilee is after S/N 18093, then the part for the gas engine hundred and '01 series should work, as well as the gas engine 4 cylinder 2000 & 4000 series.
Why not clean off your dipstick tube w/ some brake clean and put a few drops of red or blue locktite on it?? .....that's using your dipstick jimmy .
