Kiss4afrog
Besides suck it up that is.
I finally received the kit yesterday and opened it up on the table and mocked it up. The main bottom mount for the alternator the holes for the alternator don't line up and they are big enough for the bolt to rattle in them. When I put the bolt in I can see the angle of the bolt is a little uphill in one direction. That same bolt is also loose going through the bottom mount of the alternator. Since it's running on a v belt without a tensioner it's not something I want rattling around.
The vertical mount that the lower mount and adjuster mount attach to has a bigger hole in it than the adjuster does. In my world they would be the same size and tight to the bolt. Makes getting the belt tight a little difficult as you'd need to pry against the alternator to get the belt tight but also push the adjuster towards the block to take the slop out of that mismatched upper mounting hole so you don't lose the tension on the belt when you let go.
The bolt to be used in the alternator that slides in the adjuster has a lock washer but no flat washer to keep the lock-washer from fracturing when it's tightened down over that adjusting groove and falling off.
The instructions are really a joke with generic instructions and photos on one side that don't really apply to the tractor and on the other side one photo of the mounting and a I'm glad to say understandable wiring diagram.
I can make it work but I just feel I shouldn't need to bend, drill and source hardware that better fits the parts.
Call me crazy but they should also mention the belt number so you don't have to spend time researching only to find you can use the OEM length one. At least that's what I've found.
Anyone with a kit have any issues, complaints, fixes ??
