The tractor is a JD 401c with power steering. The ps valve assemble has been removed because it was leaking, I believe I can get a replacement part for this. The issue is that there is a small piece missing from the casting that the assemble casing bolts to. the piece missing is about the size of a small fingernail and is at the large hole where the steering valve passes through the casting. (enlarges that hole a little) There is still plenty of surface for the gasket to seal the junction between the casing and the casting. Is this a problem or no big deal as long as I can get a good seal? I have a photo but don"t know how to get it to show up on the forum. I can email it to anyone that would like to help. Thanks
Joe
Joe
