cjohnson11
anyone know how to hookup this offset gang disc? it has 3 point hitch hookup but i tried low arm and high arm connection and it almost tips
when going ahead. make is mid-west equiptment ltd please advise tractor is a ford 2n
Never saw such a thing, cute. I see Purple Wave has one sold a while ago, they have a like better pics than yours.
So, the cable goes to the back wheel and helps lift. That probably takes a little adjustment.
I dont understand how you mean on tipping over, what part?
You put the c clamps down along your tractor lift arms, so that lever is up, and as you lift he 3p it will change the angle of the arm, pulling on the cable to lift the rear end? It looks like?
You arent trying to leave that as a loose pivot point in the linkage?
Never saw one like that!!! I need a better picture of the hitch, that doesn't look right, maybe a picture of how you had it hooked up. That cable would have to fasten to the top of the upper link. I don't understand almost tips going ahead?
That is NOT an OFFSET disk but a disk TILLER. An ofset will have both a front and back gang of disk blades. You have only one gang so it is a disk tiller. As far as hookup I don't know anything about that. But I am guessing the back end is havy enough it needs a rear cary wheel like a semi-mount plow. Would make front end of tractor comming off ground without a way to carry the back end of the unit.
It has a rear wheel, that cable lifts the rear wheel when the three point comes up. When he has it connected right the disk hitch will be cradled in very close to the tractor so it will have better leverage on the weight as well. When you see the whole thing, it is a really neat disk tiller, probably a little light but really cool deal.
Paul
