Ozarkian
- Location
- SW Missouri
I'm needing a disk harrow, but don't really know what I'm looking for. I need a little advice on the sizing. I have a mid 80's Ford 2110 4WD 38HP (Shibaura built) that's really only ever been used to brush hog. With the rear tires filled and the loader it probably weighs 5000 lbs+, has good R1 tires, and is impressively low geared. For reference, I have been turning over heavy clay sod that hasn't been turned in 50 years or more with an old Dearborn 2-12 plow. I am plowing in 6th gear going 4.5 mph at 1800 RPMs and my tractor isn't even breaking a sweat. The ground is filled with roots too. I suspect I can handle a bit heavier disk than what you see recommended for a modern day compact tractor.
I am seeing several old 6' and 7' disks coming up for auction but don't really know what I should be looking for, or what will hook up to a Category 1 3-point. Would appreciate some advice.
