distributor
CGM
On a Jubilee 6 volt positive ground does the distributor hook to the positive side or negative side of the coil?
(quoted from post at 19:34:31 02/13/23) On a Jubilee 6 volt positive ground does the distributor hook to the positive side or negative side of the coil?
(+) coil terminal to distributor low tension terminal.
(quoted from post at 22:34:31 02/13/23) On a Jubilee 6 volt positive ground does the distributor hook to the positive side or negative side of the coil?
Coil polarity should follow battery polarity. ie: battery = positive ground, coil should be positive ground (when the points in the distributor close, current goes through to ground).
That being said, it will work either way, but will see a slightly better spark when following battery polarity.
(quoted from post at 05:47:49 02/14/23)
Thank you
Your ESSENTIAL MANUALS & DOCUMENTS come in handy. Just because you have a 6V Battery don't assume your entire wiring is setup for a 6V/POS GRN system. Verify
everything including correct timing on flywheel thru inspection cover.
Tim Daley(MI)
(quoted from post at 09:15:21 02/14/23) Your ESSENTIAL MANUALS & DOCUMENTS come in handy. Just because you have a 6V Battery don't assume your entire wiring is setup for a 6V/POS GRN system. Verify
<center><img src=https://i.imgur.com/RagVHYul.gif></center>
<center><img src=https://i.imgur.com/1mkX8oIl.jpg></center>
<center><img src=https://i.imgur.com/qNxUidtl.jpg></center>
<center><img src=https://i.imgur.com/vf1GXW7l.jpg></center>
<center><img src=https://i.imgur.com/kZ3I8kZl.jpg></center>
<center><img src=https://i.imgur.com/uEHMBAkl.jpg></center>
<center><img src=https://i.imgur.com/7Lt6l6Kl.jpg></center>
Tim Daley(MI)
Thank you
I love it when Tim replies to a question. I learn 300% more than the answer to the question asked. :lol:
I copy and file all your illustrations Tim. I stick them in the back of the FO4 manual.
