Ditchwitch v30 trencher/ backhoe
rldck20
I've got an old ditch witch v30 and I am looking for a wiring schematic for the charging system. It doesn't have an alt or generator. I have looked online and can find nothing on this machine.also does anyone have or know of a transfer case for this or a place to get one of the gears inside.
Wisconsin engine? It probably has an alternator built into the flywheel. You should see wires from behind it. My uncle was a Ditch witch dealer and had one of those. Also had one with a vibratory plow. But that was back in the 60s-70s. If it has the flywheel alternator I can help you, have a TJD manual that I think covers it. Let me know. Email's open.
Cannot help you with the gear. My former employer has two V30 trenchers. Both use the GM 10SI alternator. There should be a mounting bracket on the right side of the frame for the alternator. There should be a small pulley just behind the front shroud on the engine, just behind the distributor, that drives the alternator. You can use a 1 wire alternator or a 3 wire. If using a 3 wire the #2 wire (usually red)from the pigtail that plugs into the alternator can loop to the output terminal on the back of the alternator. The #1 wire from the pigtail (usually white) goes to switched side of ignition. It should have a diode in the white wire with the band pointing toward the alternator. The diode should be rated minimum 3 Amps 50 Volts. If equipped with an ammeter, the output wire (10 AWG) should go to the load side of the ammeter.
