diverter valve ford 800
hlhpa
I just bought a 3 point backhoe and need to add extra hydraulic lines, to my ford 800. Which diverter valve is best, and how to hook it up?
Thanks Howard
I have a plugged port on my control valve. one port supplies pressure to single action cylinder on front loader, does the same line act as return line?
Can I attack another high pressure line tp this blocked port?
then make a return line some other place, Like thread into the filler cap?
Hello Howard welcome to YT. I am no Ford guy, it
seems you are not real clear on what you are doing and
how everything is set up. So are you saying the stock
remote valve has a single hose that hooks to a port on
the valve as shown in the link? If so your remote must
be set up to work in single action. Which means the
other blocked port will have no pressure with the lever
moved the opposite direction from what raises the
loader. If you could set it to double action when ever
you wanted to operate the hoe the loader bucket
would drop to the ground. If you cannot explain it
better you will just have to make a few more post to
get your count to 5 then you can post a picture of what
you have going on. Secondly, there is a brand specific
Ford forum here if you did not know this. I will post a
link to it maybe you will get a better response there.
However, quite a few Ford guys view here.
CNHI Ford 800 hydraulic parts diagram
YT Ford forum
