DLTX-34 and 67 differences
jasonb50630
I acquired a work in progress 44 b. It was bored out to the late b bore and a set of m&w style pistons came with it. I'm close to getting it running, will it run ok with the DLTX-34 carb?
Sure it will run. My late B will run on a 34. The difference is the throttle outlet to the manifold is larger on the 67, allowing more fuel to the cylinders, equals more power.
Id "guess" it will run fine
B SN's 96000-200999 AB2711R Marvel Schebler DLTX-34
B SN's 201000-310771 AB3533R Marvel Schebler DLTX-67 NO Economizer Plug for GASOLINE ONLY (NOT All Fuel)
A bigger carb has more CFM Capacity IF NEEDED (like if more cubic inches) and if matched with enough air.
Go for it
John T
