Dltx #5 brass carb.
S Smith
I have the brass body but no float or bowl. Seems they took the cast bowl but dlx13 and dlx 7 are to big for it.I was wondering if there is any place to find the correct float and bowl for this carb? Anyone know the correct bowl number? Thanks
S Smith,
The early carbs made from bronze used cast iron bowls with a smaller hole for the 3/4" threaded stem - otherwise they are the same. Later bowls were bored for the 7/8" stem when cast iron bodies became in use. The 3/4" bowls are hard to find - I just machine a small bushing and press it in place to reduce either a DLT7 or DLT13 bowl so it will fit. The regular brass float will fit fine.
