(quoted from post at 17:49:43 11/22/11) My first question: Is this a recent rebuild??? second question: is this a 400 diesel????
If not:
If you are seeing anti freeze,it is getting time to actually repairing it.Unless you ABSOLUTELY cannot do it,it is time to start to think about dis assembly.
There is some errosion going on that the "bars leak" will only put off so long.It aint worth trashing a crankshaft over it.(Coolant is VERY abrasive on a bearing surface.)
For starts,pull the valve cover off and see if you can see any coolant around the head bolts.
Give me MORE detail,and I will give you a BETTER answer.
(quoted from post at 18:31:21 11/22/11) I am not gonna "BS" you.It is time to take it apart.
Probably either a rotted head gasket(MOST likely)or a block/head bolt thread issue(maybe).Probably UNLIKELY,cracked block.(Unless you froze it up with water in it recently???)
Issue COULD be due to electrolysis.Diesels seem to do this alot.Errosion due to low volume electrical current produced by diesel engines.I have seen MANY,MANY engines deteriorated by this!It will eat up metal,but WITHOUT rusting.
E mail me back with the valve cover off.
Mike
