Do I have a demonstrator?
Hello,
Just wondering if anyone can tell me if I have a normal Dexta or a demonstrator? I thought we were buying a cosmetically tired 1958 Dexta but the more I do with it, the more I wonder (and worry). The tractor's serial # (957E 7005) makes it a 1958 according to external_link but several have said it can't be as they didn't make a gas (petrol, for our UK brethern) Dexta prior to 1960. I was also assured that the correct color is Empire Blue but the can I got (TISCO) looks like a brighter Ford blue to me. I keep finding more sky blue the more I tear it down. The hood has a triangular plaque that says (faintly) Live Power Take Off, Live Hydraulics. The sides of the nose piece have a Ontario dealer's name in script (we're in Indiana).
I know IH was fond of putting different colors and plaques on their demonstrators. Did Fordson do so as well? I'm worried that with everything I do I might be erasing history, so any comments would be greatly appreciated!
Take Care,
Mike
Mike,
957E 7005 is probably the casting number off the transmission. The serial number is on the flange where transmission and engine bolt together. Its on the left side, right in front of the hole for the timing marks. Its stamped, not cast, so you might have to do some cleaning to find it.
Mike -
Google Oscar's Fordson Pages for all your info. You'll find the original colours were a lighter blue with orange wheels and grill. The triangular plaque was original on those tractors. Ford had no special "demonstrator" Fordsons like American Fords or IH. BTW, I wouldn't put too much faith in Tractor Data's info as I've found quite a few mistakes in their info.
I forgot to give you my 2 cents worth on the paint. Empire blue is fairly light blue. Its not nearly as dark as the old E27N Majors. Look at the pictures in the next topic down. The Majors are Empire Blue
OK, thanks for the info. I WAS looking at the wrong #. It is a probably just a plain 1961 since the numbers are closer to the '61 range and all had the plaque. I'll just paint it irregardless of color and use it.
Thanks all!
BTW, I think Oscar's Fordson Pages have been down for at least a month. At least using the 6 links I've been able to find. :-(
Take Care,
Mike
I was afraid of that. The photo shows what mine has been, NOT what I was sent (although it is labeled Empire Blue).
Oh well, if I ever tear it down I'll repaint it and NOT buy from Tisco again!
Hi;
Empire Blue is a "standard colour" and should be available over there. Take a sample from an area thats not had sunshine on it, down the steering tube through the fuel tank is a good place.
This is my 1954 Fordson Major orchard just out of the workshop. Empire Blue from my New Holland dealer matched un-faded paint inside the tank tube & inside the headlights. The orange I used was Howard rotovator orange - close enough match.
I was unsure the paint was correct colour when I opened the tin, looked too dark, but it matched the samples of original paint. We forget what the original colours were because after 50 years of sun & rain, they fade to very light blue.
BE CAREFULL though because Ford sent over the last Majors & Dextas to USA in 1963-64 with lighter shade of blue & cream hood & wheels. Your NH dealer may order this lighter/creamier shade of blue in error.
Hope this helps you.
David in Wales
David,
That is a very nice Major. I didn't even know there was an orchard model. It looks like the front spindles, the rear wheels and the air cleaner top are different from a regular Major. What else is different? Did it come from Dagenham like that or was it converted by someone else?
