Do I have the wrong carb?!
I own a 1961 Ford 821 industrial. I need to rebuild the carb. It is a marvel schebler the tag # is TSX 765. The problem is that tag does not seem to match to a 61 801 tractor. I find that number tag but not for 801 tractors. Can someone point me in the right direction? Thank you in advance!
Post from 14 years ago, might be useful to you.
awhtx
PostPosted: Mon Sep 28, 2009 4:50 pm Post subject: Re: HELP...need pic. of an M/S TSX 813 carb. Reply to specific post Reply with quote
The TSX 813 was used on the late 801/901 (change over around SN 125000) and the 4 cylinder 4000. The early 801/901 used a TSX 662 or 769. The 662/769 mounting studs were spaced on 2-11/16" centers, the 813 studs were spaced 2-3/4". The stem (hollow bolt) on the 662/769 was 3/8" and the 813 was 7/16". The fuel line from the tank to the sediment bowl on the 662/769 was 1/4", the 813 had a 5/16" fuel line. The fuel shutoff valve was the screw type on the 662/769, the 813 had a lever operated shutoff. The 662/769 was used with the 310076 manifold, the 813 got a new manifold- B9NN9425A. The 662, 769 & 813 all have the load adjusting screw on the bottom of the bowl.
If it fits the manifold, and the governor linkage is correct, and the fuel
line will connect, it will work.
Order the kit by the number on the carb.
