ou should fix the problems if you use it as a working tractor. If use is just a toy to ride around on, on relatively flat terrain, then you can get by without it.(quoted from post at 21:41:43 03/10/19) What is the point of the governor really? My arms have a ton of slop in them and it is not really moving the throttle all that much. Why couldn't I just hook up a throttle cable and a couple brackets then go on about my business?
Of course the tp20 has a governor, Governor: Continental Motors, centrifugal(quoted from post at 07:14:06 03/11/19) I could definitely be wrong, but my memory is that the Ferguson To20 (8N clone) didn't have a governor, is that correct ?
Also, I don't believe that my Kubota has a governor, although it does have a tiny foot pedal for quick adjustments.
(quoted from post at 09:14:06 03/11/19) I could definitely be wrong, but my memory is that the Ferguson To20 (8N clone) didn't have a governor, is that correct ?
hen you want to get the governor working properly.(quoted from post at 20:57:00 03/10/19)
All I use it for is grading the drive and light mowing/bush hogging
I did that once just to see. The mower revved to the moon on command, howling like a banshee. It was great until the engine died. Tearing it apart the rod had snapped. Lesson learned.Unhook the governor from your lawn mower the next time you mow your lot and see how much that little appreciated gizmo does while youre day-dreaming behind the
steering wheel!
(quoted from post at 13:22:00 03/12/19) Could also apply it to Minnesota, where the new governor is set on further undermining 2nd Amendment rights despite at one time having an A rating from the NRA. Some politicians have no compass other than the way the wind blows.
