do you know what Tractor these fit ?
found some plow stuff but I have no Idea what they fit.
do any of you know what these are and hook up to ?
thanks
not sure how to post on this board just yet so if pics don't work I will try again latter
thanks
thanks
thanks
for some reason 1 pic worked and the others did not
Hmmmmmmmm
[code:1:ee58de7d7f][URL=http://imgur.com/fECSd][IMG]http://i.imgur.com/fECSd.jpg?1[/img][/URL]
[URL=http://imgur.com/k8YxU][IMG]http://i.imgur.com/k8YxU.jpg?1[/img][/URL]
[URL=http://imgur.com/PqwxQ][IMG]http://i.imgur.com/PqwxQl.jpg[/img][/URL]
[URL=http://imgur.com/NMhtK][IMG]http://i.imgur.com/NMhtK.jpg?1[/img][/URL]
[URL=http://imgur.com/5x4Bd][IMG]http://i.imgur.com/5x4Bd.jpg?1[/img][/URL]
[URL=http://imgur.com/hp1iW][IMG]http://i.imgur.com/hp1iW.jpg?1[/img][/URL]
[URL=http://imgur.com/9Fj2z][IMG]http://i.imgur.com/9Fj2z.jpg?1[/img][/URL][/code:1:ee58de7d7f]
Here ya go.
I bought them from a guy for 30 bucks
the price was right so I figured I would be able to trade them or something if they don't fit my Tractors.
I do have an old IH CUB
it would be great if they would fit it,
Always after each picture is downloaded from your file click on the CONTINUE button, this will save the picture for your post.
Blaine,you have a mixture.The single flat disk looks
to be a stabilizer blade for a (3point)
rowcrop cultivator.The 'middlebuster has a clamp for
a common 2 1/4 diamond tool bar.The rear assy.could
be very well from a Cub.The 2 small dished disks are
covering disks for a corn cultivator.You have an
incomplete pile of parts,but its a good start!
(quoted from post at 16:37:08 01/05/13) Blaine,you have a mixture.The single flat disk looks
thank y'all very much for the help,the guy I got it from is still cleaning off a foreclosed property ,maybe I can still get the rest of the stuff that goes with it
blainenbecky, I recognize two of the pictures as a cultivator for a IH cub tractor. The one with the half circle between the plows fits on the back behind the rear wheels, there are two bolts to bolt the mounts that are on the front most part of the arms that go forward and can rotate when the plows are raised. The other part with the 2" (+ or -) square bars fit into a square hole just behind the front axle. This mount may or may not be on your tractor. If you could post some closeup pictures of your tractor we may be of more help but I don't see all the pieces that you would need to use this piece of equipment.
WaltMo
The two disks look like what we equipped our cultivator with when we hilled potatoes (last cultivation.) They are not, however JD, because they had an offset in the shank.
This link below shows what looks like a complete setup for the IH cub. Just happened to see it after I posted earlier.
http://stlouis.craigslist.org/grd/3474357121.html
after clicking on the links I see that the cultivator is an Cub hook up,
I called the guy I got it from and told him I may have left some of it
and he told me that he saw some some stuff hanging on a fence that may belong to it,I am getting Exited about the prospect of having some Cub implements other then the old woods cutter that came with it,
thanks to all of Y'all again for the help in identifying the things.
very nice and useful board you all have here .
I look Forward to getting to know it
vid test of my old cub
<object width="420" height="315"><param name="movie" value="http://www.youtube.com/v/cljKmBhUAEA?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cljKmBhUAEA?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
