Does My 640 Starter Need Replacement?
Snoho3
Sorry to ask such a simple question... When I hit the starter button on my 640, I hear a "whirring" from the starter, but it doesn"t engage or turn the engine over. Question - Does this mean I need a new starter? Or is there maybe something simpler/cheaper that is wrong? I"m quoted about $190 from a local outfit for a starter - does this sound about right? Finally - my tractor is modified to 12 volts - are starters classified by voltage? (Any difference between 12 and 6 volt starters, for example?)
Thanks for whatever words of wisdom you might have!
You probably need a new starter drive, or Bendix, as it is also known. Pins on the starter's armature shaft, it should run you $40- $60 depending on where you shop.
It sounds like the starter drive is not engaging. You can pull the starter off and take it to a local shop who can check it for you. Your tractor was converted to a 12 volt charging system and the original 6 volt starter was probably retained which is not a problem. Check the link below where they list starter drives and complete starters. Replacing the starter drive is an easy job to do. If not comfortable working on the starter yourself, take it to a local Alternator/starter rebuild shop and have them check it out.
Starter Drive
First off is your battery charged up real good?? If not then that will cause it to do that. Also could be a bad battery cable or connection. Then from there it could be a bendex or the starter.
If you trouble shoot it the way these guys have said, you still think it needs "fix'n" and you don't want to try to rebuild it your self shop around and find a place that rebuilds them. We have a local shop that rebuilds starters and alternators, just two guys in a little building and that is all they do. I took them the starter off my 960 two years ago, they totally rebuilt it, new about every thing and it was right around $100. Good luck.
Dave
Mine did this last year and what had happened was the bolts were shaken loose and the starter got caught in the flywheel and jamed. I had to use a rubber mallet to get it out. I then hooked it up to a car battery and it worked fine. I re-installed it and have had no problem since. Now I check the bolts after each field I bale. I only bale 10 to 20 acres a year.
I've had that happen. The starter drive is huge on it and is prone to getting gummed up or rusty. Take the starter out and clean the drive up. It's sort of a PITA to take apart and clean the drive, but that's what it takes. just quality time with an old tooth brush and some solvent. Last one I did that with was cleaned, assembled with a little light machine oil and it's run fine for 5-6 years.
The parts are under some spring tension, so be cautious or you will send some flying!
Many thanks for all your replies! I"ve currently got the starter in to a local shop for cleaning/rebuilding. Much better than buying a new one!
