Doing rear main seal - what else while split open?
Bvango
If I’m going to split my tractor for a rear main seal - what else would you look at and or replace while you have it all open? I’m thinking putting in a new clutch kit, trumpet housing gasket, transmission rear axel gasket, etc.
But what else would you check out or replace?
Pilot bearing and throwout bearing (part of the 'clutch kit', maybe?) and most importantly the input shaft seal associated with the transmission.
Good call I have this on my list so far - would love anything else to take a look at while I’m in there
Clutch kit - 185
Clutch release spring - 6.90
Rear axle trumpet housing gasket - 4.20
Transmission rear axel gasket - 6.90
Oil pan gasket - 8.90
Carburetor gasket - 4.10
Oil filter - 10.30
Oil pump rebuild - 107
Tie rod boots - 13.40
Transmission input shaft seal - 9
Ring gear flywheel - 49
Crankshaft seal kit - 24
Only thing I could add would be if the flywheel ring gear is installed from the back towards the front of tractor the starter drive can move the ring gear off the flywheel causing the engine to lock up or in theory I think you could saw your tractor in half.
When i had mine apart 50 years ago I checked the adjustment of cone bearings in transmission. I remember removing some shims to tighten them up a bit. I may have had to perform a double split to access. I did a static balance of flywheel and clutch cover too.
Easy if your old pilot bearing is good and free. Check you oil pump kit carefully, all directions. Have a plan when drilling the set screw hole in shaft and aluminum gear.
Can you elaborate on the set screw etc. never rebuilt the oil pump before
New bushing, you'll need a reamer to size it. In this particular kit the free gear was off centered enough that it would get tight when turning. Bad quality, offshore manufacturing, sad.
The gear is a press fit on the shaft and indexed with a set screw. It's a challenge to drill a hole 1/2 in aluminum and 1/2 in steel. A vertical mill would work. They do make a tool to index the drill for us common mechanics. Here's the hole ready to be tapped. 1/4 - 28 tap.
Where did you get this from?
