Doodlebug Project
Model AA
Just acquired this doodlebug and have identified most of the parts except the rear end. The axle shafts coming out of the differential are different lengths. Don't know if may came that way or one was cut off. Diameter about 1 3/8 inch. Tire size was 7.50 x 22. The wheels are rusted pretty bad so I need some help identifying them so I know where to start looking for more.
Any help you could give me would be greatly appreciated.
You will have a much better chance getting the proper information by going to this website,
www.ahooga.com
For the purpose of getting tires and wheels I think I would change the axle out to a newer one. Those old 22's will be hard to find if old 22 truck tires will not fit. That or change the rims on the spokes to something like 24.5's or 22.5's.
I would cut those rims off and weld good rims on there. It could be done even if the rims were a different size with a little engineering.
Richard in NW SC
Mark, I was going to say no way is that a model "A" rear. Then i looked again andrealized how much cobble and baier twine, and shade tree is in that thing. Where in the world did that reduction assembly come from? The rear axle is turned 90? to face upwards and then that gear head is bolted on. Man that Doodle bug is going to be slow. Maybe everything has been already invented once before? Hope this project is updated several times so we can see the progress.
(quoted from post at 12:39:51 07/20/19) The rear end looks like the common "banjo rear end" for a model A ford.
Yep, not the best rear for this kind of work.
The ideal setup for a Model A doodlebug is the 4 Spd tuck trans. which this one has, along with a truck differential with a 5:1 ratio or higher.
Finding one of those old truck rears used to be easy.....maybe not any more.
If I remember correctly John Deere L tractors used 7.50-22 tires and this tire size is still available new. I hope that you restore that as originally built and do not cut it up and modify it. I have seen that rear end set up somewhere, maybe an old popular mechanics article.
I think those are i,plement wheels, from picture I cannot tell if rim welded to cut off spokes or if spokes are forged tito the rim. A good close up pic of that area I could tell if welded or forged.
(quoted from post at 14:23:43 07/20/19) Mark, I was going to say no way is that a model "A" rear. Then i looked again andrealized how much cobble and baier twine, and shade tree is in that thing. Where in the world did that reduction assembly come from? The rear axle is turned 90? to face upwards and then that gear head is bolted on. Man that Doodle bug is going to be slow. Maybe everything has been already invented once before? Hope this project is updated several times so we can see the progress.
I hope it goes slow. Haven't found the brakes yet!
That's the route I have been heading. Can't find any good rims. A.E. Miller had some but he is out of that size. Spokes are welded to the current rim. Would like to cut the rim above the spokes to keep the wheels as original as possible. It's interesting to see all the thought that was put into constructing this.
A lot of thought and good workmanship too.
If you've ever tried to build a cutoff wheel you'll gain a lot of respect for all the old cutoffs which run true. You really need to build a turntable so you can turn it to check for being centered while tacking.
I think if you take the top cover off, you will find that 'reduction' box is another differential laid on its side, with the top axle tube hole plugged, and probably it's ring gear is on the input shaft of the bottom differential.
It did take a lot of thought to come up with that.
(quoted from post at 03:55:30 07/21/19) I think if you take the top cover off, you will find that 'reduction' box is another differential laid on its side, with the top axle tube hole plugged, and probably it's ring gear is on the input shaft of the bottom differential.
I did not realize what that was on top of the differential.
Now that you've pointed it out, I can see it clearly now.
Very innovative!
So.....say the top differential is a 4:1 ratio, would it now be 2:1 with one axle locked up like that?
That would probably work out pretty nicely although the extra torque might put a lot of strain on the gears and axles of the second differential.
