Double rake hitch like kyhaymans
Reid1650
I want to make a hitch to pull two rakes in tandem like this. Kyhayman yours is just like what I want to do. Is there anyway you could give me the measurements to put it together? The two pieces of iron the go from rake frame to tube for hitch, the outer tube and inner tube and how long each should be? Maybe some more pictures? Where are you in Ky by the way?
Easy answers first, I'm 12 miles south of Frankfort on US 127. Right on the Anderson Mercer County line, or thats where I am normally. Im snowed in tonight on the laptop a tad east of there, lol.
The hitch I can tell you from memory, but I sold the rake :( to a guy just down the road a ways. I built it with what I had, pc of 4 inch square tubing that was a foot longer than the width of the rear wheels. I used 18 inch long, 2 pc, of 4 inch C channel bolted to the frame where the tubing would just clear the tires. Then welded it on the bottom of the C channel. Then I used a pc of 3 inch thick wall square tubing inside the 4 inch. Its length, retracted, was even with the outside of the basket on the left side. Then I pulled it out and drilled through both pieces to anchor it retracted, 4 feet out, and 7 feet out. I used some 2.5x 3/8ths flat steel that stuck out 6 inches when welded on the 3 inch square tubing. I designed it as I built it, and have built a few others over the years.
