Olyj1947
E-mail is open. I'm needing a right side front steel spoked wheel to cut down for rubber tires. Where are you located?
Better yet, do you have one? Thank you.
Oly,are you missing the entire wheel? or is it just damaged? A while back in a RedPower Magazine(or maybe Antique Power. I subscribe to both) there was an article about a 'redneck' fix of a similar plow. The hub and spokes were goodbut the rim parts were totally gone,rusted away. He just got some automotive type wheels from a junkyard. With a little barnyard ingenunity he drilled some holes,used some J hooks and put them on to make the plow useable. One wheel acctually bolted right up to the plow.No welding or torching required. I was impressed.
The wheel center is wollowed out and wired on. It looked good setting there but went over the hill when I loaded it. I've been busy with spring work but didn't want to miss this opportunity for possible parts. The plow that I use has been converted to rubber with spoke centers and when painted look pretty good. A friend of mine in a steel repair shop wants to look at this wheel when I can get it to him.
Email sent. I have some wheels in iron pile but I'll have to match up to my plow to know what they fit. Got a tail wheel for sure. If you can post or send a pic that would help. Thanks
