Charles in Aus.
Some time ago I asked about ways to find the sewer pipe at our home . I need to tap into it for an additional bed and bath room .
The alternatives were pipe locating services at astronomical cost ! or hiring the gear , which is non existant here .
Dowsing or Witching as you seem to call it was the cheapest alternative , so with only some effort to lose I tried looking for the pipe .
Plans showed it 12 feet away from where my wires crossed . Try as I did I couldn't get a result anywhere near where the pipe was supposed to be so I trusted in the Witch .
I used a manual post hole auger and extended the handle with sections of pipe down seven or eight feet .
I hit quarter minus gravel used to bed the pipe in !
Amazed and pretty certain I had found it I dug the hole , here is the result.
While digging I found the auger had actually grazed the pipe , you can see the slight curve of the cutter in the extreme right . Fortunately it was a hand powered one !
I poured the water in the base you can see , it helped settle the gravel and make it easier to expose the base of the pipe .
