My draft control quit working (lever in the horizontal position), but when I push down on the lever further as Zane once suggested, it lifts just fine. I removed the lift cover and adjusted the draft control spring which, according to the specs, was close to 1/8" too long. My question is this - I guess I'll find out when I put it back together, but how likely is it that the problem has been fixed by this adjustment? I really don't want to take out the lift itself if I don't have to. Also, I'm changing the hydraulic oil as it looks dirtier than I expected (it was changed 100 hours ago). I note there is rust everywhere inside the case. I don't know if I should worry about little pieces of rust coming off and working their way into the hydraulic system or not (the pump cylinder is not scored). I'm thinking of using a wire brush and kerosene on the inside case. Is there a recommended way to clean this if I'm not going to disassemble it any further?
