Drained gas from tractor and generators
Geo-TH,In
I haven't used my Jubilee very much. It was put into retirement after I bought a Kubota in Nov 2019. So today I decided it's time to drain the old gas and replace it with fresh gas. Same with my two generators. Lawn mower will burn the old gas just fine. The Jubilee fired up on first crank.
What is the shelf life of E10?
Do you replace your gas or add a snake additive?
I try to use non ethanol gasoline in anything gasoline that is not operated regularly. Then I try to leave tank and carburetor dry in a dry storage environment. I use pre-mix fuels for 2 cycle engines and drain when not expected to be operated for a extended period.
George, I use aviation fuel in things that are going to be inactive foe extended periods of time, but most of those things share the hanger with the airplane, so take a little out or take a 5 gallon jug to fill when getting fuel !
I posted a comment on my using aviation gas a while back. That's what I would do, find some place where you can get a few gallons of aviation gas and use it in any tractors that you don't run often. To me, it's worth the extra cost to not have to mess with gummed up fuel systems.
If you run the carb dry, and even use the drain plug, then fill the tank well, the ethanol will stay good. it is a partial tank that allows humidity to condense in the fuel, and make a goop. I have had no issues with Ethanol in fuel. Jim
I only use ethanol in the wife's car and my pickup.
Attracts water to bad in our climate for other uses.
With that said I just got me outboard boat motor out the shop.
It has never had a drop of ethanol in it but did not get started for 2 years when I broke my back.
Cost me $500 to get the entire fuel system cleaned of varnish so it would run correctly.
First time I have ever had a problem with fuel injection and non ethanol gasoline.
Shelf life varies depending on how well sealed the container is, and the temperature.
Evaporation is what spoils it. Sealed containers might last indefinitely.
Fuel injection systems are sealed. My mom's old car was stored with E10 in the system for at least 5 years, it fired up like it had been started the day before!
Carburetor systems are not sealed. They can gum up a carb in a year if left with fuel in the bowl and exposed to heat. The tank will last a while longer, again depends on the volume, evaporation, maybe a couple years, maybe more.
Additives are a preventive, they do no good after the fact as for refreshing bad gas. Some may clean up a gummed carb, but it's a gamble.
There is also the rubber hose and diaphragm deterioration factor.
I fired up my generator with a Honda 11 hp engine on it the other day. It sat for 2 years with E10 in it. Ran just fine.
I have been watching Taryl's fuel additive test videos for 16 months, and the one engine that had straight E10 started on it, after 16 months. Not right away, but after a few pulls. One of the most interesting things about Taryl's fuel test is how much evaporation there is in vented containers, over 70% in 16 months. Some of the other engines with snake oil additives didn't start at all. What you did was a good thing, best to use the gas while it will still burn, I always keep extra gas on hand, but use it within 6 months.
I use E10 in everything.
And I've said it before on this forum, I'm probably the worst guy on Earth for leaving engines sit with whatever gasoline is in them.
I have a wheeled string trimmer that got left sitting outside over last winter. I walked past it a few days ago and it still had some of last year's gas in it, so for the heck of it I pulled the rope. It started on the second pull.
There should be counrty mark coop in your area that will have 100% gas. I use what ever the fuel man brings with no problems. My 2 fertilizer trailers have gas pumps and maybe get 1 tank of gas ran thru them and they never give me trouble. I do put a little sea foam in them if I remember.
OK, I understand why you would want to drain out the old gas. But why replace it? Maybe put a gallon of fresh gas in the tank in case you need to start it up, and fill it up the next time you put it to work. Fresh gas starts to evaporate as soon as it's in an unpressurized container, such as your Jube's gas tank.
I use Stabil from time to time, but I'm not a believer. I have yet to hear a cogent explanation of how it supposedly works from its manufacturer or anybody else.
Gas will stay fresh a long time in an airtight container. But if you have to keep it in an unpressurized container, you want fuel with the lowest possible vapor pressure. In most places, that means summer-grade fuel. Gasoline containing ethanol is usually allowed one psi more vapor pressure than ethanol-free gas, so in theory you want ethanol-free summer grade gasoline for best shelf life. Or you can buy avgas, which limited to 7.0 psi Reid Vapor Pressure.
Run cheap pump gas in everything around here and never bother with any sort of additive. Nothing ever fails to start due to gas issues even after sitting for 6 months or so. Only time I ever had a problem was with a rider that I decided to try running out of fuel as per the talk on various boards. It never started again. Haven't bothered doing anything since then.
I have 11 antique tractors that don't get run a lot and from early fall until late spring, they don't get run at all. I use Primrose fuel stabilizer. In the spring they all start up like they were ran the day before. One of my Oliver 80s Sat for seven years and 5 pulls on the crank and it was running. Maybe it's not needed but, I'm going to keep using it.
4520
When I was a kid, lead gas, no e10.
Old gas would turn to crap, smell like varnish and gum up things.
It's easy to drain old fuel and add new.
I can't see what it hurts to drain old fuel.
I think every fuel has a shelf live, with or without E10.
I've had E10 gasoline well over a year old on many occasions and never had any issues with it.
I've also used the Stabil product, and then not used it. Couldn't tell any difference.
Many of these snake oil products claim to "absorb water." Well, so does ethanol, and there's a whole lot more of that in your fuel than any preservative you'd put in.
We have been using the 10% for over 40yrs now with no problems they told me the B on a tractor ride would burn the valves but it didnt other B has mowed grass with the wOODS 59 all that time and still runs just fine
I believe fuel blends vary over the nation. I know there are a lot of guys that use ethanol bearing fuels and never, ever have an issue. In my area, E10 in a small engine, especially a 2 stroke, not used within 3 weeks to a month is CERTAIN to give issues. 100%, absolute guarantee! Take something older, say 15-20 years, and the issue can be in as few as a week or 10 days. I've got 4 saws in my shop right now that are undergoing repairs related to E-10 use. I have personally seen older fuel systems from the 50's and 60's in 4 stroke gas engines, tractors and trucks, have major issues with fuel delivery using E-10. Rebuild the carb, replace the fuel lines and filters with modern components and then it's okay, but the old stuff doesn't seem to hold up. But again, that's with the fuel I get locally. It may be different elsewhere.
(quoted from post at 19:47:23 06/15/21) If you run the carb dry, and even use the drain plug, then fill the tank well, the ethanol will stay good. it is a partial tank that allows humidity to condense in the fuel, and make a goop. I have had no issues with Ethanol in fuel. Jim
Without using a non vented tank cap or a piece of visqueen under the vented cap, that E10 will suck in water.
+1 on the E10 sucking in water. E10 in a vented tank acts like salt in a saltshaker on a humid summer day--it absorbs moisture from the air. It gets worse as the weather gets cooler and more damp.
One gallon of E10 is really 0.9 gallon gasoline and 0.1 gallon ethanol. The ethanol can absorb its own volume in water, so that gallon of fuel will swell to 1.1 gallons (0.9 gas + 0.1 ethanol +0.1 water). Then the water/ethanol suddenly separates out as a layer at the bottom.
I wash the ethanol from my gasoline by adding water to the gas can (10% by volume), shaking, and letting set overnight. Then I pour the gasoline off the top, leaving the water & ethanol behind. The gas you pour off the top will be *very* dry, and ethanol-free. I lose a couple of octane points, but these old tractors were made for 70 octane fuel to begin with.
I only do this for long-term storage in the winter. In summer I burn through gas fast enough that I just use the E10 as-is because it never sits long enough to be a problem.
The additives are really emulsifiers that just allow the water/ethanol to mix with the gasoline at a higher ratio. If let to set overnight, they will still separate out, giving you a layer of water on the bottom of your tank.
X2 ethanol gets blamed for problems they didn't cause. Never had gas line freeze up on 40 years. Ethanol is not my enemy.
How can the gas tank on a Jubilee be sealed? It has to be vented or the gas can't come out. On hot days the pressure would build up and flood the carb.
(quoted from post at 11:55:45 06/16/21) X2 ethanol gets blamed for problems they didn't cause. Never had gas line freeze up on 40 years. Ethanol is not my enemy.
I've had many, many episodes of gas lines freezing up, even after ethanol came along. It was standard practice to carry at least a half dozen cans of dry gas in our Troop cars to assist people froze up on the road. It was about the only thing we could get away with giving anyone that was owned by the State. Must be Indiana doesn't get real cold winters or maybe your gas is just better than ours.
