drawbar for IH 404 utility
racered57
This tractor has 3 pt lift drawbar, but no "solid" drawbar.
I want to pull a tree over and would like to know if pulling with a solid drawbar is better than the 3 pt drawbar if physics were considered.
I have shopped for a factory bar but no luck.
The under belly front mount is in place, just need a solid bar to install.
Do we need a picture of the tree?
If you use that drawbar to pull with a chain for any reason, keep the drawbar below the level of the rear axle, pin a clevis to the
axle and put the chain thru the clevis. If you wrap the the chain around the drawbar you will bend it.
(quoted from post at 07:43:31 09/03/20) If you use that drawbar to pull with a chain for any reason, keep the drawbar below the level of the rear axle, pin a clevis to the
You want to pin the clevis to the drawbar.
I have been skidding firewood logs for 30 years with a 2424 using only the 3 pt drawbar. I have a solid one, but it was cobbled up and did not fit correctly, so I took it off. But as noted - be very careful! I think your tractor has a short wheelbase like mine, which makes it even more prone to raise the front end off the ground when putting weight on the drawbar.
Tim
I recently read an article about tractor associated rear rollovers and the dangers of improperly hitching, especially attachment of the tow chain to a point above the drawbar. I know you are not proposing to do that, but be careful. I was unaware of this specific danger and I remember wrapping a chain around the rear axle of a tractor to pull / drag something on at least one occasion. I wont do that again. There are many documents that warn of this danger, here is one.
https://www.cdc.gov/niosh/updates/tractor1.html
