(quoted from post at 10:28:54 10/26/15)
(quoted from post at 05:44:48 10/26/15) I believe the final drives are not Super A. How do I tell ?
he original A housings:
Rear bolt has a through hole, bolt inserts from the outer side, nut goes on the inside.
Forward bolt has a blind hole, bolt screws in from the inside.
Front of housing has another through hole, identical to the rear, for attaching the swinging drawbar cross bar.
Part number should be 6827D, 6827DA, 6827DB, or 9800D (left) and 6828D, 6828DA, 6828DB, or 9801D (right).
Super A housings:
Both attachment points for the drawbar are blind holes.
Both holes are the same size.
They normally have studs and nuts for countersunk holes, but studs could have been replaced with taper-head bolts.
The front of the housing has 2 more blind holes with studs that allow the drawbar to be mounted at the forward end of the housing (for reversing drawbar to mount plow).
Part numbers will either be a "D" number larger than the ones listed above or a six digit number followed by "R" and another digit.
