Drawbar use while using sweeps....
I have an 806 that I am pulling a 14' JD sweep that has 17 shanks w/16" sweeps on it. It's the first time thru wheat stubble that has been disked and it's is a good pull. Is it proper to let the drawbar swing or keep it pinned solid? Thanks, Dan
Well, I'd say it depends on how you are working the field. If you are raising the implement when you turn, then there is no need for a swinging drawbar. If you are turning with the implement still in the ground, then it will turn much easier if you have a swinging drawbar. Hardly ever use a swinging drawbar anymore, however, I took the JD R out for some exercise this spring with a lever lift Graham Hoeme chisel and I let the drawbar loose and I was able to turn pretty easily with the chisel still in the ground.
Forgot to tell you I was lifting at the turns. Years ago when we run the GB minnies, we let the drawbar swing all the time except when we plowed. Thanks for the info. Dan
Wow, I hadn't seen the words Graham Hoeme since I used one in the 1950s for an uncle in North Dakota. I pulled that one with a JD "R" too. Are there still many Graham Hoemes around in Kansas?
