Drying another batch
jon f mn
In spite of a few problems and a busy weekend otherwise, I did get a batch of corn done. The old DC just seems so at home there I think I'll just run it.
I did a short video of it during the day for those who asked how it worked. Corn must be getting dry because this batch only took 3 hours total, that's not long at all
Drying corn.
I don't know how wet your corn is or what you are drying it down to, 10 or 12%, perhaps?
Any idea how many propane $$$ and gasoline $$$ for the tractor it takes to do the job?
Would be nice if the waste heat from the engine/radiator/exhaust could be added to the air stream!
Looks like it takes about 20% of a 500gal propane tank. And it takes less than 10 gallons of gas in the tractor. I don't have a tester but I would guess this is 20% or less out of the field and shooting for just under 15 since this will be sold. I'll get it tested this week to see where I am. I'm sure this is pretty dry right out of the field because it was dried and cooled in about 3 hours. That's pretty short as we always figure 4 hours a batch.
Jon, you need a moisture tester so you know when to take it out,if u leave it in too long you're wasting gas and well you no the drill !!
You're spending a lot of time and money,I'm farther South but in my area we would have turned the calves and hogs loose in the corn field let them do the work and over seeded rye.Another bonus is no manure to clean out of the barn the animal have already spread it for you on the fields.
Have only seen that once. Farm had three 500 GT dryers, ran a pipe from exhaust to fan
on each one from Deere utility tractors running dryers.
I do not understand your statement, please explain.
Planting cover crops gets harder the further north you go, as there is barely enough season for the base crop. I do believe in letting animals clean up a field after harvest, but that takes good fences, which can take a lot of time.
What's to understand? By letting the animals do the harvesting,no fuel to buy,no equipment to run,no drying the corn,etc.Same animals eating the same crop just not in an orderly fashion but the work and other expenses are either zero or very low.As far as fences why not have all fields fenced so livestock can be put on them?
I still do not follow.
Around here, there is a surplus of corn, most feed is purchased and not from farm, most fields are not fenced.
