Does anyone have experience with vibration dampners on a IH Dt466 engine. I am putting a DT466 in a 1086 and would like to use the dampner from the DT 414 along with the DT 414 flywheel. I have about decided to use the truck front case along with the MW pump. There would be a need to build the motor mounts if the truck front case is used. The only reason to use the truck front case is to use the larger oil pump. The suction pipe is larger and the front case has a larger suction area for the larger pump. Any help will be appreciated. The tractor is just a special farm tractor, not used for anything but mowing.
